How to turn the "Multiple icons" off?
ddvc
Post by ddvc »
When I browse some have exe or shortcut folder. xnview will popup this.
it's tooooo stupid.
I just want to see image files.
Can i turn this off?
Re: How to turn the "Multiple icons" off?
You can remove the EXE extension from filelist
ddvc
Post by ddvc »
xnview wrote:You can remove the EXE extension from filelist
Thanks for your reply,How to remove the EXE extension from filelist
This si the filelist option
marsh
Post by marsh »
Add EXE to a custom field and unmark not to show it.
{EXE}
Also, look at filter setting in browser's toolbar, mentioned here:
-Handling ONLY images files.
