MP 0.26.1 (WinXP): Problem with Cyrillic characters
murkka
Post by murkka »
My local settings are Bulgarian (cyrillic) and I heve problems with unicode in EXIF Info. IPTC and XMP are OK.
Re: MP 0.26.1 (WinXP): Problem with Cyrillic characters
murkka wrote:My local settings are Bulgarian (cyrillic) and I heve problems with unicode in EXIF Info. IPTC and XMP are OK.
Could you send me a sample?
murkka
Post by murkka »
Is this sample OK?
IPTC seems to be in Latin, and not in unicode. XMP data seems to be correct.
same here: http://newsgroup.xnview.com/viewtopic.php?f=62&t=20637
There is a bug for EXIF.XPTitle&XPAuthor
murkka
Post by murkka »
I use both Latin and Japanese/Cyrillic. If I use just Japanese it looks like that:
I means IPTC encoding is Latin and not unicode, which software do you use?
murkka
Post by murkka »
WinXP Pro Service Pack 1 ?
murkka wrote:WinXP Pro Service Pack 1 ?
I think that XP use XMP, not IPTC
murkka
Post by murkka »
I made a few experiments and concluded that the problem is within my OS. In Local setings - Language for non-Unicode programs when I use Bulgarian (cyrillic) I can see cyrillic but not japanese. When I use japanese I see both languages in IPTC and XMP with no problems, but I'm forced to use bulgarian.
Is there anything that can be done? Is there a way for XnView to be unrelated to local encoding and still use unicode?
murkka wrote: Is there anything that can be done? Is there a way for XnView to be unrelated to local encoding and still use unicode?
You must write IPTC in unicode
