I'm using XnView RC2, and there are 2 options I don't understand.
Use Shell context to open picture.
Use Embedded thumbnail.
What do these 2 options mean ?
Thanks a lot
That depends on if you prefer speed or quality. Most digital cameras embed small JPEG preview thumbnails directly into the large JPEG images. It's a small image inside the original, large image. The small image is what you get when you quickly browse through the images on the camera in playback mode. XnView utilizes these small images to create thumbnails lightning fast. Instead of taking the whole image and downsizing it, it just takes the small image and shows it.To enable or disable Embedded Thumbnail, which one is better ?
Why ?
