Something weird on tab's action
liglow
Post by liglow »
well, you open the browser tab first, and you open 2 pictures in the browser. Now you have 3 tabs, right? I set the mouse scroll action to the pre/next file, which is working normally, but if you active the 3rd tab, and click the 2nd tab with center button, you'll see the 2nd tab is closeed(which is right), but now the mouse stroll is not work properly. sometimes it turned to be switch between different tabs, sometimes it has no action at all.
1.97.2 don't have this issue, but 1.97.6 have.
My english is bad, so ...
Re: Something weird on tab's action
I assume your problem is related to topic Messy order when tabbing through tabs.
EDIT:
When looking closer at your problem I think it's a problem of focus on tabs and setting "Previous/Next file". :bug:
liglow
Post by liglow »
Not exactly.
He's problem is re-sort tabs, and my problem is failed to switch to pre/next file with stroll button in the same tab, after we closed the inactive tabs with center button click when we had more than one tab .
liglow wrote:Not exactly.
As added in my "EDIT" part, your problem is really different: Focus behaviour and Scroll behaviour are both applied to the tabs when focus is on the tabs, result is a wrong behaviour.
liglow
Post by liglow »
according to your reply , i suddenly realize the bug is based on when you center click the tab, the tab toolbar get the focus, but center click means to close the tab, so ... the focus lost.
