In XnView DeLuxe 2, when previewing photos in thumbnail mode I typically use the arrow keys. However, I've noticed in this new version that lines do not wrap in a normal fashion. When I'm at the end of a line, I can only move up, down, or back, not forward. To move forward I must hit the down arrow, which then forces me to browse the photos in an "S" pattern.
Is this a bug, since I've never noticed it before. If not, please fix because it's a big annoyance. (I'm browsing/previewing the thumbnails by name and using WinXP Pro SP-1.)
XnV-DeLuxe: Thumbnail view does not wrap
zridling
- Zaine Ridling
The Great Software List
Re: XnV-DeLuxe: Thumbnail view does not wrap
I can confirm your observation: In XnView DeLuxe 2.0 the "Cursor Right" key does not wrap to the next line (or "Cursor Left" to the previous line).
Like you, I'd expect the next image to be displayed when pressing "Cursor Right". And I cannot see a benefit if navigation does not wrap. So I think that this should be changed/fixed in XnView DeLuxe.
crazytb
Feedback about Linux version
Only a note about Linux version of free XnView 1.50. In this version, the navigations wraps. I this behavior also occurs in next versions.
It's not ahelmut wrote:I can confirm your observation: In XnView DeLuxe 2.0 the "Cursor Right" key does not wrap to the next line (or "Cursor Left" to the previous line).
