Thank you for creating XnView, I have used it for years.
I recently updated to version 1.97.6 (June 17, 2010) and noticed a small bug.
"Options -> Read/Write-> YUV 16 Bits"
and
"Options -> Read/Write-> YUV 16 Bits Interleaved" are reversed.
When I checked "...Interleaved", XnView saved files in the normal "non-interleaved" format.
When I checked the non-interleaved box, saved files came out correctly for my workflow i.e. "interleaved"
Thought you should know.
Thank you.
Saving Files in YUV 16 bits Interleaved - reversed
DrVideo
Re: Saving Files in YUV 16 bits Interleaved - reversed
There is no such option??? You means 'save as'?DrVideo wrote: "Options -> Read/Write-> YUV 16 Bits"
and
Right, there is no Option "Interleaved". There's only the file types "YUV - YUV 16Bits" and ""YUV - YUV 16Bits Interleaved". Is this what you mean and which works just the other way round, DrVideo?xnview wrote:There is no such option??? You means 'save as'?
