There's an error in viewing TIFF images 48bit with LZW compression.
Best regards.
Paco.
Viewing TIFF images
Peter2
More info necessary ...
Which error?
What happens? What happens not? What commands are you using? Which version of XnView? which OS? Which kind of file: scans, prints, ...
Peter
Peter
xp_zxp
Re: More info necessary ...
Sorry Peter and everybody. Too short my message.Peter2 wrote:Which error?
Peter
I use the latest version in an Win XP system. We cannot view any TIFF 48bit LZW compressed file. The only we can see is a noisy gray image. It seems to me that XnView doesn´t deal LZW compression in the correct way.
BR.
Paco.
Peter2
Re: Viewing TIFF images
Have you tested it with other viewer-software? Is it OK there? And is the file OK?
Peter
Peter
xp_zxp
of course. Eg Picasa and othersPeter2 wrote:Have you tested it with other viewer-software? Is it OK there? And is the file OK?
Peter
Paco
could you send me a sample?xp_zxp wrote:There's an error in viewing TIFF images 48bit with LZW compression.
xp_zxp
I'm going to send you via mail.xnview wrote:could you send me a sample?xp_zxp wrote:There's an error in viewing TIFF images 48bit with LZW compression.
BR.
Please try XnView 1.97.7
xp_zxp
Hi Pierre. Now works properly but I found similar problem with TIFF 16 bit gray LZW compressed files. Probably it's the same bug but in this case in TIFF gray images.xnview wrote:Please try XnView 1.97.7
Thanks.
Paco.
Could you send me the file please?xp_zxp wrote:Hi Pierre. Now works properly but I found similar problem with TIFF 16 bit gray LZW compressed files. Probably it's the same bug but in this case in TIFF gray images.xnview wrote:Please try XnView 1.97.7
xp_zxp
Sample sent by mail Pierre.
Thank you.
BR.
paco.
Thank you.
BR.
paco.
