2 Basic Questions
plantation
2 Basic Questions
Post by plantation »
Question 1
I am using Xn View to copy pages of microfilm. I scan multiple pages creating multiple tabs but I have not been able to figure out how to save all the tabs at one time.
I am only able to save one tab at a time.
Anyone know how to save multiple tabs.
( I have tried the shift and Ctrl keys- that does not work.)
Question 2
After I have saved multiple tabs to a file i.e Scan 1, scan 2 -- Scan 20
One I start scanning additional files the tabe begin renumbering at the beginning and I have to rename each tab before I save it or they will overwrite the original files I saved.
any suggestions?
Thanks for your assistance
Great to find this board
Re: 2 Basic Questions
plantation wrote:Question 1
If you 'close all', you'll be asked to save picture
Question 2
Yes a known issue
eL_PuSHeR
Post by eL_PuSHeR »
Just scan into a multipage TIFF. It's easier.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
