<Moderator's note: This post was split from topic 'RC2: xnview doesn't show folders with custom icons'>
I'd like to know how EgoSun and Dreamer highlighed the picture with different colors. I understand how to do the screenshot (capture) in XnView, but how did you highlight parts of that screenshot with yellow, pink and green? Did you use XnView to do that or another application?
OT: How to hightlight areas in screenshots
SeaMaiden
- Skype: janeocean50
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
** XnView ROCKS **
Lesmo16
@SeaMaiden:SeaMaiden wrote:I'd like to know how EgoSun and Dreamer highlighed the picture with different colors. I understand how to do the screenshot (capture) in XnView, but how did you highlight parts of that screenshot with yellow, pink and green? Did you use XnView to do that or another application?
You can do that with PAINT - think you know it.
Everyone who believes in telekinesis, raise my hand!
Dreamer
I used just link to that screenshot.SeaMaiden wrote:I'd like to know how EgoSun and Dreamer highlighed the picture with different colors. I understand how to do the screenshot (capture) in XnView, but how did you highlight parts of that screenshot with yellow, pink and green? Did you use XnView to do that or another application?
Think you cannot do this with MS Paint. Think there's two ways to achieve this:
1.) Use a graphic program that supports opacity (e.g. Corel PhotoPaint, Adobe Photopaint).
2.) Use some kind of trick in XnView (or other graphic programs):
a. In XnView, open an image and select an area which you want to highlight
b. Menu "Image > Adjust > Brightness/Contrast/Gamma/Balance"
c. Activate "Apply to image", and then play with the RGB balance. The adjustment will be applied on the selected area, only.
d. Confirm with "OK" if you are happy with the result.
Lesmo16
Lesmo16 wrote:You can do that with PAINT
Sorry I wasn't right, but Helmut is ...Helmut wrote:Think you cannot do this with MS Paint.
Please try PhotoFiltre - it does it!
Like xnView, it's a very fine Freeware from France.
