Busted Title Bar EXIF tags?
realistik
Post by realistik »
I had XnView set up to show some EXIF data in my title bar (as well as in fullscreen view). I updated to 1.97.7 today and for some reason none of the EXIF data is displaying in the title bar now, although it still shows up fine in fullscreen. Did something change or possibly break?
EDIT: Specifically, the EXIF data is stuff like f/stop number, shutter speed, ISO value, etc.
Re: Busted Title Bar EXIF tags?
Right a bug in 1.97.7 :-(
realistik
Post by realistik »
Ah, bummer. Well you can't make the omelette that is XnView without breaking the occasional egg... :) Thanks for confirming, and keep up the good work!
