I have recently tried 'XnView-win-de_1.97.7.0.exe' under a current WinXP. I noticed that 'sort' in 'batch rename' seems not work correctly? Whatever sort option is selected, the file sequence does not change at all.
Whenever I switch back to 'XnView-win-de_1.97.6.0.exe' everything works fine (tried two times).
Best regards gobi49
Sort in BatchRename (1.97.7.0)
Re: Sort in BatchRename (1.97.7.0)
Right a bug in 1.97.7
eL_PuSHeR
This seems to be also true when adding the first pages inside Create Multipage file. They appear unsorted.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
