Windows 7 + mts-files: No sound
chrisly
Post by chrisly »
Hi.
When looking mt2s-Files with XnView on a Windows7-PC there is no sound (Vista: no problems).
Playing mt2s-files with VLC, KM-Player ... on Windows 7-PC: sound ok!
Has anyone else this problem?
Is it a bug?
Thanks for help! :)
chrisly
Re: Windows 7 + mts-files: No sound
Post by chrisly »
No Windows 7-User here?
Or isn´t it a Win7-problem? :?:
chrisly
Post by chrisly »
Hi.
I´ve now installled XnView 1.97.8.
Still no sound ... :(
chrisly
Post by chrisly »
Now I´m back from 2 weeks snorkeling in Egypt - with more than 2000 pictures and mts-videos. :shock:
It´s great that mts-playback now works with Xn-View - but still without sound. What´s the problem? My PC or XnView + Windows 7 + mts?
Please help me - it would be easier to get an overview if XnView works with sound!
Edit: the mts-playback with XnView works, but only haltingly (I hope you understand what I mean - sorry for my poor English).
The same Video played with VLC or KM-Player: no problems (it´s not a hardware-problem!).
Could you send me a MTS file please?
chrisly
Post by chrisly »
You can try one of this:
http://www.dslr-forum.de/showpost.php?p ... stcount=83 (the first one - "Delfine" - is the shortest)
Thanks for help!!!!! :D
I use ffmpeg codec, and i have sound with this mts (win 7)
chrisly
Post by chrisly »
That´s interesting! :D So the problem isn´t Windows 7!
But XnTriq wrote this:
XnTriq wrote:
matt1696 ([url=http://newsgroup.xnview.com/viewtopic.php?p=79927#p79927]MP4 videos not shown in XnView after installing ffdshow[/url]) wrote:That's why I don't trust codec packs. With the mixture of their installing so many utilities and all the other things that people have on their PCs, you end up many possible routes that can be taken to play a file. Then when something doesn't work because a preferred route causes a conflict or something, it's difficult to pull them apart and force the player to use a particular method.
Better to keep it clean and install something like FFDshow that does most things, and then a few extra splitters and codecs that are needed in addition when you come across them.
But basically it's a minefield!
After that warning I´m afraid to install new codecs.
I think it should work without installing new codecs cause Win7 has native support for AVCHD. And it works with WMP, VLC ...
Only with XnView: no sound
Maybe you can modify XnView? :?: That would be great!!!
chrisly
Post by chrisly »
Hi.
Now I´ve installed ffdshow but there ist still no sound.
Any other idea? :(
marsh
Post by marsh »
chrisly wrote:Hi.
Any other idea? :(
Have you tried the other MS media player? The one which existed from the Win2k era (productive looking, less chrome). Not w.m.p. version 12. If it also has no sound, there is likely a codec, settings problem.
chrisly
Post by chrisly »
How can I try it on W7?
marsh
Post by marsh »
chrisly wrote:How can I try it on W7?
Oh, the old player (wmp6.4) isn't in recent OS according to Wikipedia article, Windows Media Player.
chrisly
Post by chrisly »
Hi.
Now I´ve installed the new version 1.98.5.
And everytime I install a new version I hope for sound when playing mts-files in XnView - without success. :(
Vista=sound / Win7=no sound
It could be so beautiful ...
The problem is not XnView, it use installed codec...
chrisly
Post by chrisly »
xnview wrote:The problem is not XnView, it use installed codec...
But it works with VLC, WMP, KMPLayer ...
Maybe XnView is using a "wrong" codec?
I´ve tried everything (installing new codecs ...). Now I´ve no more ideas. :(
Maybe you can find a way to change something in XnView?
