Capture screen - parameters for naming the screenshots?
joeyeti
Post by joeyeti »
Hi guys,
I am using the Capture Screen tool much lately and therefore I would like to know what are the other parameters to name the captured screens (files) apart from the default "capture_[mdY_HMS]" format? For instance, does a parameter exist to name the file after the captured window's title etc.?
Is there a reference perhaps?
Or do they apply for XnView as a whole and are listed under a different part of the application funcionality?
Thx!
Joe
Re: Capture screen - parameters for naming the screenshots?
You have # for a number
joeyeti wrote:Is there a reference perhaps?
joeyeti
Post by joeyeti »
Thx XnTriq!
