My left side pane in Xnview is very narrow. (This is where the Tree Pane and Preview Pane are.)
For some reason, I can't drag the separator bar with my mouse. When I hover the mouse across the separator bar, the cursor does not change to show me that I can drag the bar to make the pane bigger. Can anyone help?
Can't resize Tree Pane
Re: Can't resize Tree Pane
Probably you happened to click on the small arrow in the middle of the resizer bar and thus have hidden the tree pane. Click on the small, light blue arrow in the middle of the left side '>' or use menu "View > Tree Pane > Show" or short cut Ctrl+Shift+F.miffo wrote:My left side pane in Xnview is very narrow. (This is where the Tree Pane and Preview Pane are.)
- Forum Librarian
Dreamer ([url=http://newsgroup.xnview.com/viewtopic.php?p=72419#p72419]May i lock the splitter bar?[/url]) wrote:To unlock it, first close XnView, then open the xnview.ini file in notepad, find option LockLayout=1 , change the value to 0 and save the file.
See also: Pb avec la modification de taille des différentes zones » Ratés ?ckv ([url=http://newsgroup.xnview.com/viewtopic.php?p=73420#p73420]UI-less Settings[/url]) wrote:LockLayout:
When enabled, XnView will lock browser layout so user cannot resize preview, folder or file panes.
Value: Boolean (1/0), disabled by default
I doubt that "LockLayout" is the reason miffo's problem. Nevertheless very interesting links, XnTriq, I didn't even know that there's such a setting "LockLayout".
