OSX NConvert Installation
jordoco
Post by jordoco »
I am trying to run NConvert from the OSX Terminal without much luck. Double clicked and expanded the maxosx.tgz file in the Download directory. Double clicking nconvert returns the following without a prompt to exit:
** NCONVERT v5.62 (c) 1991-2010 Pierre-E Gougelet (Apr 23 2010/10:18:25) **
Version for MacOS X (All rights reserved)
** This is a freeware software (for non commercial use)
Usage : nconvert [options ...] file ...
Type nconvert -help, for more information
logout
[Process completed]
Starting NConvert from the terminal in the Downloads directory simply returns:
-bash: nconvert: command not found
Looked around and found about adding nConvert to the .profile but having difficulty with that too. NEWBIE ALERT!
Any help would be greatly appreciated... :D
Re: OSX NConvert Installation
There is no installation, you must run nconvert from a terminal
./nconvert
jordoco
Post by jordoco »
Got it - THX
