Load dicom files with 16 bit
josei
Post by josei »
Hello
I need to read a 16 bit dicom file, I tried GFL_LOAD_ORIGINAL_DEPTH, but it does not seem to work.
It is possible with GFLSDK?
This is the code I use
	load_option.Flags |= GFL_LOAD_SKIP_ALPHA;
                if(_parl(8))
	         load_option.Flags |= GFL_LOAD_ORIGINAL_DEPTH;
	load_option.Origin = GFL_BOTTOM_LEFT;
	load_option.ColorModel = GFL_BGR;
	load_option.FormatIndex = _parni(7)==NULL ? -1 : _parni(7);
	error = gflLoadBitmap( _parc(1), &TheBitmap, &load_option,NULL);
Re: Load dicom files with 16 bit
josei wrote:Hello
Currently GFL SDK can't read DICOM 16bits, only TIFF/PSD/PNG/SGI/TDI
