i've just installed xnview 1.97 on windows xp/home.
it recognizes my brother mfc4420c scanner.
when i did acquire to, i selected multipages, i selected to pdf, it scans my document and abends.
i get a windows message asking me to select the debugger.
was i supposed to install something else, besides the standard xnview 1.97?
do i need xconvert?
thx
acquire to abend
- Forum Librarian
Re: acquire to abend
It's a known issue: XnView abends on scanning
Adding the line newMethod=1 to the [Scan] section of my xnview.ini did the trick for me and my Samsung SCX-4100:
xnview.ini wrote:Code: Select all
[Scan] Digit=0 Directory=X:\Temp\ FileName=scan_ FormatName=pdf Multi=1 Page=0 Reverse=0 StartIndex=1 Subfolder=0 newMethod=1
