Copying files to the preset folder doesn't seem possible from the starting point of the tag category. It appears the direct copy, <ctrl + alt + c> is only folder to folder?
1. Tag files from multiple folders.
2. Highlight all files in tag category.
2. Use "copy to folder" from menu. <alt +c>
3. Each file in tag category is copied to a chosen favorite folder. ex: R:\
4. Use the direct copy to default folder <ctrl + alt +c > also to R:\
5. *No files are copied. A dialog always appears saying problem with source file.
v.1.97.6 Direct copy from tag category to default folder
marsh
marsh
Re: v.1.97.6 Direct copy from tag category to default folde
Fixed in v.1.98b1
