XPM - Format does not appear correctly.
Leksey
Post by Leksey »
Hi, I'm install XnView 1.97.8, and noticed that the XPM format files do not display correctly. The files are OK to 100%. Even if we try to convert in another format, then the problem do not disappears, the file will not display correctly.
Microsoft Windows XP Pro (x64) SP2 - Version 2003
QuadCore Intel Core 2 Quad Q9550, 2833 MHz (8.5 x 333)
GeForce GTX 260 (896 mb)
8192 Мб (DDR2-800 DDR2 SDRAM)
Leksey
Re: XPM - Format does not appear correctly.
Post by Leksey »
Leksey
Post by Leksey »
The old version worked fine.
Leksey
Post by Leksey »
Many thanks for your work.
Leksey
Post by Leksey »
Hi! It's me again and new problem in opacity, but with the PNG format.
could you post the png?
Leksey
Post by Leksey »
