Multipage file
silveringchap
Multipage file
Post by silveringchap »
Hi There. How do you create a multipage PDF file ? Evertime I run the multipage tool and add PDF documents, it doesn't save the multipage document. Kindest regards
Re: Multipage file
Are you trying to merge several PDF documents?
silveringchap
Re: Multipage file
Hi, yes that is the idea.Scan all the documents in and save as PDF, then merge them into one.
