24-bit PNG - troubles adding an alpha
rkwright
Post by rkwright »
OK - I feel like I'm missing something. I have a 24-bit PNG that has a background value of 254,254,254 that needs to be made transparent.
I haven't had luck with any combination of the flags below (using nconvert 5.60):L
-ctype rgba
-add_alpha "value" (what is "value" supposed to represent? Can't find info in docs)
-merge_alpha
-transpcolor 254 254 254
Any thoughts on how to make an RGB png into an RGBA, with 254,254,254 having an alpha of 0?
I'd appreciate it.
Re: 24-bit PNG - troubles adding an alpha
rkwright wrote:-add_alpha "value" (what is "value" supposed to represent? Can't find info in docs)
value is the alpha that you want to add
krawhitham
Post by krawhitham »
nconvert.exe -out tga -add_alpha alpha.tga -overwrite main.tga
produces a 100% black alpha channel in main.tga
I'm I using the wrong command?
no -add_alpha 255
