MP 0.30 req: Icon's should display the highest page possible
budz45
Post by budz45 »
I think that icon's opened in MP as normal, when the Snapshot feature is not enabled, should show the highest icon page first. So if a .ico has the highest page of 256x256 rgb then it should display that, if another .ico has highest page of 48x48 rgb then it should show that. So the highest icon page in the highest quality should be displayed first. Same should apply to .icns icon files as many .icns icon's have the highest 512x512 possible.
Currently in 0.30 and before we got first-display situations like this; http://i52.tinypic.com/ngogn6.jpg - where only on some icons the lowest quality icon would show.
So now for example instead of currently displaying like this; http://i55.tinypic.com/2nufc3.jpg it would simply display as this; http://i56.tinypic.com/2n902h0.jpg (highest page first with rgb).
BTw this feature is already in Xnview Shell Extension
This topic may be related to these issues:
http://newsgroup.xnview.com/viewtopic.php?f=34&t=19879
http://newsgroup.xnview.com/viewtopic.php?f=62&t=21033
budz45
Re: MP 0.30 req: Icon's should display the highest page poss
Post by budz45 »
This already works on .icns, so highest page first should be supported on .ico too.
