retain old settings
dan
retain old settings
Post by dan »
i downloaded the latest version 1.97. how do i keep my old settings from previous versions? i keep the xnview.ini file in the application itself. i used to be able to replace the ini file with the old one but does not work for me anymore
Re: retain old settings
In about dialog, you have the pathname for .ini used
dan
Post by dan »
i dont understand your reply
dan
Post by dan »
i got it now. i recopied the ini file from the last version again. obviously user error. in version 1.97 it shows the file location. i was looking in version 1.91 which of coarse does not show the location. thanks for your reply.
