Occasionally, a thumbnail of a png with orientation flag will not be rotated (while the image preview is correct). The miniature is rotated as expected if XnView.db is removed before program is launched.
Using sample from this topic:
http://newsgroup.xnview.com/viewtopic.php?f=60&t=20005
Settings:
Cache turned off.
v.0.30w png orientation and db
Re: v.0.30w png orientation and db
Are you able to reproduce it?
marsh
Rotate icon always disappears after the second restart with 0.31 (the second session with program after one which db was created).xnview wrote:Are you able to reproduce it?
I can't reproduce, i have the iconmarsh wrote:Rotate icon always disappears after the second restart with 0.31 (the second session with program after one which db was created).xnview wrote:Are you able to reproduce it?
