Some things I noticed in View mode:
1. PgUp and PgDown don't work anymore in View mode ( in 0.26.1 it did).
2. Edit|Crop opens a toolbar every time you select it. So click Edit|Crop 3 times and you have 3 toolbars.
3. When I cropped a picture (forgot to save it) and closed the tab, I was not asked if I wanted to save the file.
4. When the crop toolbar is visible and you close the tab, xnview crashes.
5. When the crop toolbar is not visible, it is still posible to draw a selection which disapears after left mouse botton is released.
Pierre..... Your program is great!!
JohanP
MP 0.30 Win7 (64): View mode
JohanP
Re: MP 0.30 Win7 (64): View mode
I have not this problem, PgUp/Down works correctly... In Option/Interface>Shortcuts, do you have PgUp/Down for Next/previous file?JohanP wrote:1. PgUp and PgDown don't work anymore in View mode ( in 0.26.1 it did).
JohanP
I found the cause of the problem (but don't understand how it can happen):
I installed MP 0.30 in the same folder as MP 0.26 because I wanted to use the same settings and layout,
but PgUp and PgDown don't work (shortcuts are set correctly).
As a test I installed MP 0.30 in a new blank folder and PgUp and PgDown work fine.
But now I don't have my settings and layout.
What would you suggest?
1. Use the cleanly installed 0.30 version and copy the ini- and style-files from the old 0.26 folder or
2. Use the 0.30 version installed on top of 0.26, with deleting any files no longer need.
JohanP
JohanP
The shortcuts are good?? Strange. File next/previsou in toolbar works?
JohanP
Yes, shortcuts are OK.xnview wrote:The shortcuts are good?? Strange. File next/previsou in toolbar works?
File next/previous in toolbar works.
File next/previous in popup menu works.
PgUp/PgDown in thumbnail view works.
Testet with Win7 (64) and Win XP.
JohanP
JohanP
I am very sorry, but I have overseen something.JohanP wrote:Yes, shortcuts are OK.
In v0.30 I used the same shortcuts of v0.26, but in v0.26 I had PgUp/PgDown only selected in the browse mode section.
Nevertheless PgUp/PgDown worked in view mode. Not so in the new version.
After selecting PgUp/PgDown in the view mode section of the shortcuts tab it works fine.
Sorry Pierre!
JohanP
