Selection in file pane after TAB cycling
larsen
Post by larsen »
after cycling through the browser view elements, there is no active selection in the file pane.
Steps to reproduce:
- Open XnView in browser mode
- Have folders "1" and "2"
- Select folder "1" and select an image in that folder
- Select folder "2"
- Press TAB twice
Focus is now in file pane, but no file is selected. On pressing "down cursor", the first entry ".." gets selected. When you now press TAB to cycle, the selection is also visible in the file pane.
IMHO also the file pane should have the first entry selected when it gets the focus for the first time.
Lars
Re: Selection in file pane after TAB cycling
larsen
Post by larsen »
Thx, works fine.
