Rename Folder under Bookmark
Quero
Post by Quero »
Hi Folks,
when I select the bookmark, I can not rename directories. Is this a bug?
Thanks for your help.
Quero
Schinzer
Re: Rename Folder under Bookmark
Post by Schinzer »
i have the same problem. But i couldn't find any answer of this "Bug" here in the forum.
Is the solution for all clear? Or only for some users?
Thanks.
Bookmark is a "read only" view, so you can't move/delete/rename subdirectories
