Show Information
maudale
Show Information
Post by maudale »
I turn on View -> Show Information. When I close and restart XnView the option is not selected. Is there an option to make this "sticky" so I don't need to set it every time I open XnView?
Re: Show Information
:arrow: maudale
:) Hello !
• The answer is THERE :wink:
- Please, scroll to the paragraph :
[View]
ColorInfo= …
:mrgreen: KR
maudale
Post by maudale »
Thanks for the fast answer. I set ColorInfo=2, but it still doesn't stay.
:arrow: maudale
:) Again…
• It works still fine here, I checked.
- Ensure you that you changed the right used INI ! See in the Options >> System Integration.
- If so, that doesn't work till you restart XnView (because there is no Reload_INI command, unfortunately :()
:mrgreen: KR
maudale
Post by maudale »
I checked, the right INI is used and I have restarted XnView. The information is shown in Full Screen, but not the Viewer.
