Risk by update?
xntest
Risk by update?
Post by xntest »
I have been using nconvert for resize and lossless rotating since a few years.
It works fine.
Now I see a new version and I would like to know if it is better to keep the old version 4.79 from 2007, or is it better to update to the latest version form 2010.
I don't use it often but I convert pictures that are worthwhile for me so that I don't want to loose them.
Is the new version of nconvert as stable as the old version?
Re: risk by update
if you are happy with your version :D it's not necessary to download last version...
xntest
Re: risk by update
Post by xntest »
Thanks.
I was not sure if the new version maybe is more stable, safer or faster.
Re: risk by update
Yes, newer version are always more stable and sometimes faster...
