RC3: Shortcut for Browser->norm. Fullscreen
Locked
Hacker
Post by Hacker »
I think there should definitely be an option to enter normal fullscreen immediately, without going through "View" first. Now I have two choices to view an image in Fullscreen:
a) view it in lite fullscreen, which is not satisfactory at the moment, however, because, read ahead / cache behind are not supported.
b) view it in View first and the switch to fullscreen, but that is one step more than in 1.74.
So, until lite fullscreen supports read ahead / cache behind, I'd like to have an option to get to normal fullscreen from Browser by pressing Enter.
Roman
CLP
:) Hi Roman !
- You can launch too XnView with the CL parameter -full to get the full-screen at start-up ;)
:mrgreen: K R
Hacker
Re: CLP
Post by Hacker »
Clo wrote:- You can launch too XnView with the CL parameter -full to get the full-screen at start-up ;)
Thanks but I do not want fullscreen at startup. I want normal fullscreen from Browser.
Roman
Re: RC3: Shortcut for Browser->norm. Fullscreen
Hacker wrote:Ia) view it in lite fullscreen, which is not satisfactory at the moment, however, because, read ahead / cache behind are not supported.
I'll add Read ahead/Cache behind too in fullscreen from browser.
Dreamer
Post by Dreamer »
Both options added.
Locked
