Fullscreen keyboard navigation
Evds
Post by Evds »
How can i go to the next/previous image in fullscreen ?
I tried page up/page down, the arrow keys but none seems to work ?
Relaxed
Re: Fullscreen keyboard navigation
Post by Relaxed »
the page up/page down keys work just fine for me, also in fullscreen mode.
testing conditions:
- XnView MP 0.31 on Ubunu 10.10 x64 via WINE
- Files: JPG
What file extension do your photos have? maybe fullscreen browsing doesn't work with certain formats?
Have a nice weekend @ all
Cheers
Relaxed
oops66
Post by oops66 »
OK, that's work but....
You have to customize by yourself your shortcuts into: Settings\Interface\Shortcuts for both Items Modes ( 1-) Browser mode, and 2-) View mode &FullScreen mode too.
PS: Especially if you are kept your old xnview.ini file, it's what why, it's better to try each XnViewMP beta versions with a fresh xnview.ini file and Xnview.db file. (I also had the same problem)
Evds
Post by Evds »
Thx oops66,
Indeed, my shortcuts in Settings\interface\Shortcuts where a bit messed up (yep, i kept my ini file from the previous installation: lesson learned; Clicking the defaults button solved the problem and the F11 problem a had to switch to fullscreen and back again).
It's a very nice feature to be able to customize the shortcuts in that way ! (thx Pierre)
Is it possible to define more then one shortcut for a command ?
for example: to go to the next file in Fullscreen (cmd_filenext) i would like to use PageDown or RightArrow.
Evds wrote: Is it possible to define more then one shortcut for a command ?
Currently not possible...
