MP 0.31 - auto image size problems
vilisov
Post by vilisov »
Setting "auto image size" in viewer to "no fit".
Now selecting a thumbnail to open viewer. Image however appears to fit screen (small), although "no fit" ticked.
Also when browsing through images in viewer: First it always loads a fit image (small), although "no fit" is ticked. Then after a second it switches to original size. This is somehow inefficient. It cannot switch to original size at once without preloading a resized image?
Re: MP 0.31 - auto image size problems
I can't reproduce. You select a file in the browser, and open the viewer? Here the picture use 100% zoom
vilisov wrote:Also when browsing through images in viewer: First it always loads a fit image (small), although "no fit" is ticked. Then after a second it switches to original size.
:bugconfirmed: for these files...
  1. Download all JPEGs from anaglyph.htm to an empty folder.
  2. Flip through images with Previous file (PgUp) / Next file (PgDown).
... in conjunction with these settings:
  • View » Auto image size » Fit image to windows, large only
    Tools » Settings » View » Misc. » Cache:
    • [   ] Read one image ahead
      [   ] Keep current image
Pierre, I think it has to be related to SIMD somehow, because I can reproduce this behavior only with images in JPEG format.
Dimensions of all 9 images “jump” from 212×172 to 423×344 pixels.
---------------------------------------------------------------------->8
Ok, for JPEG viewer load preview and after the full resolution picture....
Is it a problem... It's to have quickly the picture...
EDITED: Ok, the problem with size occurs only in 'No fit'
:bugfixed: in beta 0.32
