"Always on top" button on toolbar
mantis3d
Yahoo Messenger: goldenmantis2000
Post by mantis3d »
There is no "Always on top" button on toolbar, so if i want toggle "Always on top", I have to go into Options, to toggle it on interface tab.
Cant you add a button? Make it easy to use.
thank you.
Re: "Always on top" button on toolbar
Really? You use 'Always on top' often??
JohnFredC
Post by JohnFredC »
xnview wrote:Really? You use 'Always on top' often??
I use it frequently...
One layout I use is a smaller-than-screen-size window that I float over web pages , etc.
Support+
Every function should be available for the toolbar!!!
John
JohnFredC wrote:Every function should be available for the toolbar!!!
This function is not yet available :-D
