(I post this issue again here in the "bug reports" section since I'm not sure if it is acknowledged in the old thread in the "suggestions" section.)
For the last two versions XnView has supported the PLD file format. But unfortunately there are still some special PLD files it doesn't display properly. I have posted an example file here:
http://newsgroup.xnview.com/viewtopic.php?f=34&t=20525
Problems with PLD support
