In view mode (v 1.97.8 ), I use the "in title infos" feature with the following syntax :
<Filename With Ext> - <Focal Length 35mm>mm - ISO <ISO Value> - f<F-Number> - <Exposure Time> s
The filename is correct, but the infos are these of the previous displayed picture.
If I display the "on picture infos" option ('I' Key) with the same infos as in title, there is no problem.
If I remove the buffer for previous/next picture, it does not change anything.
So it seems to be a bug...
The title info feature shows previous picture infos
pierrederonsard
pierrederonsard
Re: The title info feature shows previous picture infos
In fact, it seems that the bug-fix (viewtopic.php?f=35&t=20782&p=86621) in 1.97.8 created a new bug.
I reinstalled 1.97.6 > OK.
