1st image always the same in random slideshow
baliscus
Post by baliscus »
When creating a random slideshow I always get the same image in 1st place (the 1st from the selected folder) while the others are correctly randomized.
I remember I created a random slideshow with an older version with no problems. I use version 1.97 (Nov. 2009).
Is there a solution? Was this corrected in 1.97.8 if it was a bug? It's not in the change log.
This only happens when the keys are activated (not a timed slideshow). I'd like to use the keys, though.
I intend to create an .exe but the problem also accurs in the preview .sld.
Thanks.
baliscus
Re: 1st image always the same in random slideshow
Post by baliscus »
Posting myself the solution I just found:
On the main slideshow options screen check timed (say 7000 seconds or any high number to make it virtually indefinite) and disable using mouse for transitions, just under that box .
Then click on more options. Another options panel will come up. Check enable mouse (first box).
