Mouse wheel left/right functions
Dreamer
Post by Dreamer »
I know, the side buttons are not working good yet, but the new standard is here - mouse wheel left/right. In web browsers and documents it's used to scroll horizontally.
I suggest to add support for wheel left/right, it should be configurable, as mouse wheel.
Thanks.
Dreamer
Re: Mouse wheel left/right functions
You means option/Mouse for wheel mouse left/right?
Dreamer
Post by Dreamer »
Right, I'm using wheel left/right all the time, in browsers to toggle tabs, in mp3 player to change track etc.
In XnView - browser, thumbnails view, I'm using it to go to previous/next folder, I don't need to go up, select [..] item, press Enter, press right, and press Enter again, I can do it all with the wheel. It's amazingly fast, very useful, I'm using HotkeyP, if anyone cares:
Hot key: Mouse Left
Command: Command to active window
Parameters: 336 xnview.exe&XmainClass
Hot key: Mouse Right
Parameters: 337 xnview.exe&XmainClass
In view mode and fullscreen it might be used to zoom (wheel up/down to switch to prev./next image). This is not possible using HotkeyP, because XnView is using the same Window class for browser and view mode.
More in the FAQ.
Dreamer
jiangelvera
Post by jiangelvera »
i have use left wheel mouse, Thumb control roller,make your hands comfortable.
Prevention of mouse hand.
need more informations,pls contact me via skype:jiangel_vera
