Morning I downloaded XnView as I understood it supported .bmf files - I get the message that the foramt of the file could not be determined.
We are a school and some of the staff used BOARDmate software to create slides for the interactive white boards; problem is all the slides, literally hundreds, are created and saved as a .bmf format. I can't seem to find a program that can open them, and , ideally convert them to jpegs or something more universal.
The original program has been 'misplaced' and is no longer made.
So does this program support .bmf? If it does is there any pointers you can give me to resolve why it can't open our .bmfs.
Many thanks
.bmf support?
Re: .bmf support?
You need to download BMF plugin
Re: .bmf support?
FAQ 'Does XnView support graphic format .xyz?' might be helpful.
