How do you install XnView on Windows 7?
I donwloaded the Full version 1.97.8 to my Windows Seven system. The XnView-win-full folder was created and an XnView folder inside this one with all the files. It is NOT installed as a program. Windows Add/Remove programs does not see it. I can run it by starting the file xnview in that XnView folder. I tried all the files in the folder bit none run an install.
Help!
Windows 7 Install fails
Re: Windows 7 Install fails
Is it the setup that you have downloaded?
