jpg file size
jpg file size
Not sure whether this should be a suggestion for a future version or whether it already exists and I just don't see it: when I save a file as a jpg, XnView allows me to change the quality with a slider that ranges from 1 to 100. That's fine but I would like to know the change in actual file size as I make the change. Am I missing something?
Re: jpg file size
Hello, maybe you can check here: Tools\Export\... then \Save as ...
Re: jpg file size
Thanks oops66, that exactly what I needed.Hello, maybe you can check here: Tools\Export\... then \Save as ...
