IPTC: Updating XMP destroys some of it
marjoleink
Post by marjoleink »
I'm a long-time user and fan of XnView, but unfortunately I now have a problem to report.
I have started to add IPTC data (and other meta data) to my photographs. My strategy for this is:
  1. use Phil Harvey's ExifTool for 'bulk' operations, such as location and creator data which can be added a whole directory at a time or even across a directory tree
  2. use XnView for finer-grained data like sublocation and keywords, where having a thumbnail view helps in determining what the content should be; I always have the setting 'Update or create XMP' on (UpdateXMP=1 in the [Iptc] section of xnview.ini)
    Once reason for using this combination is that both programs have, in my experience, excellent support for the actual image and meta data standards.
Alas I found that whenever I make a change that should have a reflection in XMP, not only is XMP data updated with this (correctly), but a whole chunk of pre-existing XMP data is discarded at the same time. In particular: the group CreatorContactInfo, part of the Iptc4xmpCore group disappears. Just adding a single keyword for instance, correctly adds this to the XMP data as well as the IPTC section but at the same time destroys the CreatorContactInfo (leaving only the Iptc4xmpCore:CountryCode field which is part of the Iptc4xmpCore group but not part of the CreatorContactInfo subgroup).
Obviously, this should not happen: XMP should be modified or extended with new data entered in the dialog, but existing (unmodified) data should remain untouched.
Example XMP data (as shown by XnView):
- before:
<?xpacket begin='' id='W5M0MpCehiHzreSzNTczkc9d'?>
<x:xmpmeta xmlns:x='adobe:ns:meta/' x:xmptk='Image::ExifTool 7.98'>
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
 <rdf:Description rdf:about=''
  xmlns:Iptc4xmpCore='http://iptc.org/std/Iptc4xmpCore/1.0/xmlns/'>
  <Iptc4xmpCore:CountryCode>IND</Iptc4xmpCore:CountryCode>
  <Iptc4xmpCore:CreatorContactInfo rdf:parseType='Resource'>
   <Iptc4xmpCore:CiAdrCity>Amsterdam</Iptc4xmpCore:CiAdrCity>
   <Iptc4xmpCore:CiAdrCtry>Netherlands</Iptc4xmpCore:CiAdrCtry>
   <Iptc4xmpCore:CiAdrExtadr>Geuzenstraat 35-3</Iptc4xmpCore:CiAdrExtadr>
   <Iptc4xmpCore:CiAdrPcode>1056 KA</Iptc4xmpCore:CiAdrPcode>
   <Iptc4xmpCore:CiUrlWork>http://iamback.com/</Iptc4xmpCore:CiUrlWork>
  </Iptc4xmpCore:CreatorContactInfo>
 </rdf:Description>
  xmlns:dc='http://purl.org/dc/elements/1.1/'>
  <dc:creator>
   <rdf:Seq>
    <rdf:li>Marjolein Katsma</rdf:li>
   </rdf:Seq>
  </dc:creator>
 </rdf:Description>
  xmlns:photoshop='http://ns.adobe.com/photoshop/1.0/'>
  <photoshop:City>Madurai</photoshop:City>
  <photoshop:Country>India</photoshop:Country>
  <photoshop:State>Tamil Nadu</photoshop:State>
 </rdf:Description>
</rdf:RDF>
</x:xmpmeta>
<?xpacket end='w'?>
- for the same file after adding a keyword:
<?xpacket begin="" id="W5M0MpCehiHzreSzNTczkc9d"?>
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.1.1">
      <rdf:Description rdf:about=""
            xmlns:Iptc4xmpCore="http://iptc.org/std/Iptc4xmpCore/1.0/xmlns/">
      </rdf:Description>
            xmlns:dc="http://purl.org/dc/elements/1.1/">
         <dc:creator>
            <rdf:Seq>
            </rdf:Seq>
         </dc:creator>
         <dc:subject>
            <rdf:Bag>
               <rdf:li>cycle rikshaw</rdf:li>
            </rdf:Bag>
         </dc:subject>
      </rdf:Description>
            xmlns:photoshop="http://ns.adobe.com/photoshop/1.0/">
      </rdf:Description>
   </rdf:RDF>
</x:xmpmeta>
<?xpacket end="w"?>
System data:
OS: Windows Vista Home Premium (Dutch version)
XnView: latest (1.97.8)
References: If you need any more info, please let me know!
_______________
Marjolein Katsma
Re: IPTC: Updating XMP destroys some of it
<!-- OT //
  • Welcome, marjoleink! I used to be a frequent visitor of hshelp.com and wouldn't mind if you were to become a regular contributor at newsgroup.xnview.com ;o)
// OT -->
marjoleink
XnTriq wrote:<!-- OT //
// OT -->
Ha! A blast from the past. :) Thanks for the welcome, XnTriq!
_______________
Marjolein Katsma
marjoleink
I am surprised, and rather disappointed, that even after a whole week (during which I can see 'xnview' has been active non the forum), there still has not even been an acknowledgement of my serious bug report. :(
Destroying existing contact information in a file is not something that should happen and is something that needs to be fixed.
What gives?
Marjolein Katsma
_______________
Marjolein Katsma
JohnFredC
Post by JohnFredC »
Hi Marjolein
AFAIK Pierre is a one-man show with "many irons in the fire". Currently I think he is readying a new beta version of XnView MP, which may have his full attention.
In my experience, all important bugs are promptly addressed and the minor ones prioritized according to the volume of noise from the users.
Your post was very informative and helpful for the process.
John
marjoleink
John,
I'm not asking for an immediate solution. I know one-man shows need sleeptime as well. :)
But I know Pierre has been on the forum and replied to some posts since I posted my report. All I would like to see is acknowledgement that this is, indeed, a bug. It looks as though it's just being ignored now.
Marjolein
_______________
Marjolein Katsma
Sorry, yes i've seen your problem :-) Even if i don't reply... I'll check asap
marjoleink
xnview wrote:Sorry, yes i've seen your problem :-) Even if i don't reply... I'll check asap
Thank you Pierre! Glad to know you're at least aware of the problem.
Cheers,
Marjolein
_______________
Marjolein Katsma
