Hello.
When transforming PDF to TIFF (Create multipage file) the resulting TIFF file is always 24bpp (True Colour) even if source PDF was indexed palette.
Keep colour depth transforming PDF > TIFF
eL_PuSHeR
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Re: Keep colour depth transforming PDF > TIFF
Could you send me a sample?
eL_PuSHeR
Yep. Here you go.
When using same compression (ZIP/Deflate) size should be similar.
http://www.megaupload.com/?d=AKXA6NUD
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
