I've tried batch processing a few images located in the same folder, but the process only applies to files with a name that includes numbers in sequential order.
For example, if the folder includes files named DSC_0741, DSC_0742, DSC_0812 and DSC_0813 the process only applies to either DSC_0741and DSC_0742 or DSC_0812 and DSC_0813 depending on what file is highlighted in the input menu.
Am I missing something, or isn't it possible to process all images in a folder?
Batch processing and file names
Re: Batch processing and file names
'Batch convert' start with the selected files, so select all your files
