MP 0.32 thumb selection ratio
ElQuia
Post by ElQuia »
OK, first congrats, nice work over 0.31.
Question: Why can't I set the thumbnails size ratio manually like I can in xnview 1.97 ?
For ex I use in 1.97 all my thumbs " 16:9
With MP I cant chancge that or I'm so stupid I don't find where to do it....
help please :shock:
"Death smiles at us all. All a man can do is smile back" - "No hay Camino hacia la libertad. La Libertad es el camino."
Re: MP 0.32 thumb selection ratio
yes right, not added yet...
You can edit the xnviewmp.ini to put your thumbnail size :-)
ElQuia
Post by ElQuia »
:D OK, that worked, would be nice having an "options" item for it.
You know what else is missing?: a button or "separator" " "button or keyboard shortcut that can be easily used like in 1.97 to hide the tree pane, instead of having to navigate "View/Tree Pane/Show". That would be REALLY handy
ElQuia wrote:You know what else is missing?: a button or "separator" " "button or keyboard shortcut that can be easily used like in 1.97 to hide the tree pane, instead of having to navigate "View/Tree Pane/Show". That would be REALLY handy
Yes, but where? in the title of pane?
ElQuia
Post by ElQuia »
1.97 has that sort of little "button" or area on the divider between the thumnail & the tree pane. It`s sort or darker area with a lef pointing arrow (in blue) when tree is open and right pointing arrow when tree is closed.
Could be that, could be an optional icon to add to Filelist toolbar, whatever suites you better as designer :D
ElQuia wrote:1.97 has that sort of little "button" or area on the divider between the thumnail & the tree pane. It`s sort or darker area with a lef pointing arrow (in blue) when tree is open and right pointing arrow when tree is closed.
I can't add such button like 1.97, so i need to find another way
ElQuia
Post by ElQuia »
simple, little icon on the filelist toolbar?, It would be VERY cool having the option to save 3 or 4 layouts and put an icon for each on the toolbar .... :twisted:
ElQuia wrote:simple, little icon on the filelist toolbar?, It would be VERY cool having the option to save 3 or 4 layouts and put an icon for each on the toolbar .... :twisted:
So be able to have 'custom layout' in toolbar will be good?
ElQuia
Post by ElQuia »
It would be good having an icon that could change between say 3 or 4 sustom layouts or one icon for each custom layout ... of course optional, maybe there are guys who don't want such thing...
