0.32 Request: Rename this menu item
budz45
Post by budz45 »
Hi again,
This menu item in the Browser's right click is a very useful feature in which I use;
It would be better to rename it, in English, as Explore file's folder or Explore folder of file
EDIT:
I renamed the topic 8)
Re: Rename this menu item
I also find this command very useful and use it a lot.
Context menu(s) for search results in Everything:
  • Folders
    • Open
    • Open Path
    • Explore
    • Explore Path
    • Copy Full Name to Clipboard
    • Copy Path to Clipboard
  • Files
    • Open
    • Open Path
    • Explore Path
Murray Gordon: Command Line Pointers for Windows Explorer
budz45
Post by budz45 »
XnTriq wrote: [*]Explore Path
Yes thank you, Explore Path is an even better name to use :)
'Explore Path', really better?
budz45
Post by budz45 »
xnview wrote:'Explore Path', really better?
It's just a matter of my opinion really, especially when written in English. Also it's only two words which is concise.
I finnaly think, Explore Folder might be better (in english). Since the computer terminology of 'folder' is more known to more users than the than the word 'path'.
What do you think Pierre?
As for the Everything search engine, Explore Path opens an Explorer window with the folder tree on the left and the file pane on the right, while Open Path opens the folder in single-pane view (no folder tree).
In XnView Classic, we have Open containing folder in the context menu for files and folders.
In XnView MP, there's Open containing folder [Ctrl+O] (always greyed out) and Open in file explorer.
budz45
Post by budz45 »
Yes!
The "Open containing folder" was what I was looking for. But why is it greyed out?
budz45 wrote:But why is it greyed out?
You tell me ;o)
  • Image
The keyboard shortcut (Ctrl+O) belongs to cmd_OpenView :bug:
"Open containing folder" is used for search or category result. To go to the folder of the picture...
