Pierre,
I like the "quick sort" toolbar of the browser of the M32-win version very much,
however there are some problems with selecting the items on this bar.
If I select "none" of the itmes , then only "name" is available,
but then I can't seem to get other items to be selected,
that is: you can select them by placing a checkmark,
but on the header only "name" keeps being displayed.
Rene
EDIT: should have tried that right-away: after restarting XnView it picks up the selected items again.
quick sort toolbar problem
rra
Re: quick sort toolbar problem
You means the header sort toolbar in thumbnail view?
rra
yes indeed,
I also noticed that some time (or most of the time ?),
the selection of which items are placed on the bar isn't saved.
René
René
You can't add items in this toolbar?rra wrote:yes indeed
Can't reproduce, in detail column width is correctly saved...I also noticed that some time (or most of the time ?),
rra
No, I tried it just once more,
I can't add items or delete them: that is I CAN add and delete them,
but XnView forgets about it, when i restart XnView.
I use windows-7 - 32bit and use the Xnview.ini - file in the XnView directory
No problem on my 7.rra wrote:No, I tried it just once more,
In details or thumbnail view? You add an item, close XnView, and restart it?
rra
It happens in thumbnail-view , not sure whether it also happens in details-view.
If I restart then the modifications in the toolbar are not visible.
Should these settings be visible as text in the xnview.ini file ?
René
René
rra
Found it !!! ,
it appeared that my xniew.ini-file had no write-permission.
It somehow happened when i copied this ini-file from another MP32 installation on an other computer.
I should have seen that before.
Thanks anyway.,
Rene
Thanks anyway.,
Rene
