Description background
DenTNT
Post by DenTNT »
Is there any way to set background for <Annotation>?
Very often is too hard to see the text.
For example, light colors of photo and white text color...
Re: Description background
You can set background color
DenTNT
Post by DenTNT »
xnview wrote:You can set background color
Color of background of PHOTO, not description string! The background of description string is transparent!
If you enable background color, the text is not transparent
DenTNT
Post by DenTNT »
Where can I do that?
DenTNT
Post by DenTNT »
I've found it! Thank you for your help and your program!!!
