I notice that the duration of an audio or video file is read by XnView -- it is displayed under Properties on the Preview tab, as "Length".
It would be great to also place the duration/length in one of the columns of the main panel for immediate display.
If adding a new column is not convenient maybe put the info in the Properties column (otherwise empty for audio/video)???
This would VERY USEFUL !!
Thanks Pierre
audio & video durations
meRobs
Re: audio & video durations
I have recently updated to version 1.98.
And, as before, I note that the Propeties column contains the dimensions of image files -- good !
However, this column is empty for audio and video files.
Rather than add the option to customise the columns, by adding Dimensions and Duration, like other Explorer-like Apps do, I suggest you could make use of the empty Properties column.
Please insert the duration values for Audio & Video files into this column.
After all, the values are available to you. They are on the Properties tab of the Preview pane (as "Length").
