MP 0.32
macos
MP 0.32
Post by macos »
On the left and the following window will be set up a flexible?
Like xnview 1.9, flexible
Re: MP 0.32
What do you means?
macos
Re: MP 0.32
Post by macos »
xnview wrote:What do you means?
Re: MP 0.32
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=89019#p89019]MP 0.32 thumb selection ratio[/url]) wrote:
ElQuia wrote:1.97 has that sort of little "button" or area on the divider between the thumnail & the tree pane. It`s sort or darker area with a lef pointing arrow (in blue) when tree is open and right pointing arrow when tree is closed.
Could be that, could be an optional icon to add to Filelist toolbar, whatever suites you better as designer :D
I can't add such button like 1.97, so i need to find another way
Re: MP 0.32
You can hide pane
Re: MP 0.32
  • Tools » Settings... » Interface » ToolBar
    • Browse mode » Thumbnails view only
macos
Re: MP 0.32
Post by macos »
There is no easy or 1.9
Re: MP 0.32
What do you means by 'chinese can't be imported'? Here you have chinese in the search box!
macos
Re: MP 0.32
Post by macos »
xnview wrote:What do you means by 'chinese can't be imported'? Here you have chinese in the search box!
chinese in the search box is "help" info. MP language is Chinese
Re: MP 0.32
Sorry i don't understand your problem...
JohnFredC
Re: MP 0.32
Post by JohnFredC »
Maybe he wants buttons on the splitters as in 1.9x?
That's an incredible feature that would make MP quite a bit easier to use.
John
