Options - Keyboard/Mouse - Switching modes - Use ENTER to switch between: - Browser > Fullscreen > Viewer
Options - General - Operations - Mode when starting with a file - Fullscreen-Browser
1. Open an image file from Explorer (click on it or press Enter)
2. Alt-Tab back to Explorer and open another file
3. Press Enter to get into Browser mode
4. Alt-Tab to the window with the first opened file
5. Press Enter. Nothng happens. Expected - switch to Browser mode
Roman
Enter does not switch view modes when more files opened
Hacker
Re: Enter does not switch view modes when more files opened
Explorer, is it windows explorer?
Hacker
Hello Pierre,
Yes, Explorer is Windows Explorer. The file manager does not really matter, though, same with Total Commander.
EDIT: This seems to be working fine in 1.98 beta 1.
Thank you
Roman
Thank you
Roman
